跳转到主内容
Repairing Quasar Microwave Sparking Inside
你所需要的
  1. Repairing Quasar Microwave Sparking Inside, Disassembling Quasar Microwave Outer Cover: 步骤 1 中的图像 1,1
    • Disconnect the power supply cord from the outlet.
  2. Repairing Quasar Microwave Sparking Inside: 步骤 2 中的图像 1,2 Repairing Quasar Microwave Sparking Inside: 步骤 2 中的图像 2,2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Repairing Quasar Microwave Sparking Inside: 步骤 3 中的图像 1,2 Repairing Quasar Microwave Sparking Inside: 步骤 3 中的图像 2,2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Repairing Quasar Microwave Sparking Inside: 步骤 4 中的图像 1,3 Repairing Quasar Microwave Sparking Inside: 步骤 4 中的图像 2,3 Repairing Quasar Microwave Sparking Inside: 步骤 4 中的图像 3,3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
    How to replace the Fuse
    Fred Schlaich - 回复
  5. Repairing Quasar Microwave Sparking Inside, Sparking: 步骤 5 中的图像 1,1
    • First check to see if the interior of the microwave is dirty. Food or tin foil could be the reason that the microwave is sparking.
    • If the interior of the microwave is dirty, clean it. A spotless interior is recommended. The interior should look like the example in the picture.
  6. Repairing Quasar Microwave Sparking Inside: 步骤 6 中的图像 1,1
    • If the microwave continues to spark after the interior has been cleaned, that could indicate that the diode may be broken. The diode is what attaches the capacitor to the back of the microwave.
    • A multimeter can be used to measure the resistance of the diode. The multimeter must be on the resistance setting or the diode check setting. If the diode reads zero in both directions, then it is broken.
  7. Repairing Quasar Microwave Sparking Inside: 步骤 7 中的图像 1,1
    • Sparking inside of the microwave may also be the result of a broken or misaligned magnetron. If this is the case, it is recommended to take the microwave to a qualified professional or completely discarding the unit and purchasing a new one.
    • Fixing the magnetron without the aid of a qualified professional is NOT recommended. The magnetron is an emitter of microwave radiation and tampering with it may lead to serious injury or death.
结论
6等其他人完成本指南。
Michael
于09/26/12注册
222 声望
创作了2篇指南
团队
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G12
3 名成员
创作了6篇指南
一条评论
Is the magnetron the failing component if you have this microwave or perhaps a 1983-1985 model quasar brand and the microwave doesn’t turn on after hitting “start”, a timer goes but no microwave heating is engaged?
Eric Ouyang - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 4,293
