跳转到主内容
Repairing Puppet Strings
你所需要的
  1. Repairing Puppet Strings, Repairing Puppet Strings: 步骤 1 中的图像 1,1
    • Detach the severed/damaged strings. This can be done by cutting them or carefully pulling them out.
  2. Repairing Puppet Strings: 步骤 2 中的图像 1,1
    • Thread the fishing line through the needle as you would with thread and tie a simple knot to secure the fishing line.
    • Note: Tying the knot can be tedious, so it may take a few tries.
  3. Repairing Puppet Strings: 步骤 3 中的图像 1,1
    • Insert the needle into a secure part of the puppet's feet or other necessary puppet part.
    • Note: The material may resist the needle at first.
  4. Repairing Puppet Strings: 步骤 4 中的图像 1,2 Repairing Puppet Strings: 步骤 4 中的图像 2,2
    • Pull the needle through the puppet part and tie another simple knot directly onto the location that was threaded through.
    • Note: You may want to tie a few simple knots for extra security.
  5. Repairing Puppet Strings: 步骤 5 中的图像 1,1
    • If you need to make a handle, take the two wooden sticks and cross them to where they are perpendicular to each other.
  6. Repairing Puppet Strings: 步骤 6 中的图像 1,1
    • Secure the two sticks with tape or glue where the two sticks cross.
    • Note: Tape is a faster fix, but may appear messier.
  7. Repairing Puppet Strings: 步骤 7 中的图像 1,1
    • Tie a knot around the stick handle to secure the fishing line. (it may take several knots to secure the fishing line and you can adjust the length as needed with scissors)
    • Note: Repeat the previous steps to other parts of the puppet if necessary.
  8. Repairing Puppet Strings: 步骤 8 中的图像 1,1
    • This is what your puppet should look like.
    • Happy puppet-ing!
结论
2等其他人完成本指南。
团队
Missouri Western, Team 1-4, Adkins Fall 2015 Missouri Western, Team 1-4, Adkins Fall 2015 的会员
MWSU-ADKINS-F15S1G4
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 31
总计 2,984
