跳转到主内容
Repairing Polaroid Sun 600 LMS Gear Train
你所需要的
  1. Repairing Polaroid Sun 600 LMS Gear Train, Open film door: 步骤 1 中的图像 1,2 Repairing Polaroid Sun 600 LMS Gear Train, Open film door: 步骤 1 中的图像 2,2
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Repairing Polaroid Sun 600 LMS Gear Train: 步骤 2 中的图像 1,1
    • Locate small silver gear in top left corner of film bay.
  3. Repairing Polaroid Sun 600 LMS Gear Train: 步骤 3 中的图像 1,1
    • Using a plastic opening tool, rotate gear downward until jam is cleared.
结论
5等其他人完成本指南。
Matthew Lessig
于01/20/10注册
63 声望
创作了3篇指南
团队
Cal Poly, Team 3-18, Maness Winter 2010 Cal Poly, Team 3-18, Maness Winter 2010 的会员
CPSU-MANESS-W10S3G18
4 名成员
创作了4篇指南
3条评论
How do you know if the jam is cleared ? I have the same camera but the problem with mine is the shutter button. Every time I press the red and black one it won't make the noise or spit out the film unless I go one button behind. Although when I do that the photo comes out black. I think the two buttons or supposed to be together so when you press the red and black button the one behind it moves in sync. I really need help on fixing it and I'm not sure if what I said made any sense but I need help.
Tiffany - 回复
I have this very same problem…You explained it perfectly, however, I can’t figure out how to fix it. Please someone help us!
Jordan Brown -
Currently trying to fix it but after the steps it isn’t working. How do I know how many times to turn the gear?
Eleanor Murphy - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 76
总计 9,113
