当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Take the flathead screwdriver.
Insert it into the slot located at the bottom of the handle and turn counterclockwise to release the bottom cap.
The second image shows the amount of turning needed to loosen the bottom cap.
Hold the handle upside down, and push down on the shaft to release the internal components of the handle.
这个步骤还没有翻译 帮忙翻译一下
Take the small Phillips screwdriver.
Tighten the small screw that can be found near the top of the device internals
Hence, unscrew the screw completely and put some superglue at the end of it. Then tighten it again. This prevents the screw to get loose due to the vibrations.
13等其他人完成本指南。
7条评论
thanks for that one - you rescued ours from a premature trip to the landfill :)
Excellent guide; a simple fix saves $$ and waste. Thanks!!
Thank you! It's realy help me!
