跳转到主内容
Repairing Paint Brush Bristles
你所需要的
  1. Repairing Paint Brush Bristles, Repairing Paint Brush Bristles: 步骤 1 中的图像 1,2 Repairing Paint Brush Bristles, Repairing Paint Brush Bristles: 步骤 1 中的图像 2,2
    • Identify the brush type and the level of damage:
    • If the brush hairs are inflexible due to hardened paint coats, proceed to Step 2.
    • If the brush hairs are synthetic (fraying bristles), proceed to Step 5.
  2. Repairing Paint Brush Bristles: 步骤 2 中的图像 1,2 Repairing Paint Brush Bristles: 步骤 2 中的图像 2,2
    • Fill a small cup half way with turpentine.
    • Soak the brush in the turpentine for 2 days.
    • CAUTION: Do this in a well-ventilated area. The fumes from turpentine are toxic.
  3. Repairing Paint Brush Bristles: 步骤 3 中的图像 1,1
    • Remove any amount of paint that may remain on the brush by moving the brush in a circular motion.
  4. Repairing Paint Brush Bristles: 步骤 4 中的图像 1,2 Repairing Paint Brush Bristles: 步骤 4 中的图像 2,2
    • To remove remnants of turpentine on the bristles, wash the brush thoroughly in water.
    • After the turpentine has been completely removed, proceed to Step 7.
  5. Repairing Paint Brush Bristles: 步骤 5 中的图像 1,1
    • For synthetic brushes, boil a pot of water.
    • CAUTION: Avoid any contact with hot objects.
  6. Repairing Paint Brush Bristles: 步骤 6 中的图像 1,2 Repairing Paint Brush Bristles: 步骤 6 中的图像 2,2
    • Place the brush in the boiling water.
    • Rotate the brush in the water for approximately 5 minutes.
    • You should begin to notice that the bristles will start to come back together from the heat and water.
  7. Repairing Paint Brush Bristles: 步骤 7 中的图像 1,2 Repairing Paint Brush Bristles: 步骤 7 中的图像 2,2
    • Gently dry off the brushes using a soft towel.
    • Stroke the brush in an upward motion and be careful not to dig the towel through the bristles.
  8. Repairing Paint Brush Bristles: 步骤 8 中的图像 1,3 Repairing Paint Brush Bristles: 步骤 8 中的图像 2,3 Repairing Paint Brush Bristles: 步骤 8 中的图像 3,3
    • In order to retain the brush shape, use a brush tube or wrap the bristles in aluminum foil.
    • Within approximately three hours, the brush bristles will be back to normal.
  9. Repairing Paint Brush Bristles: 步骤 9 中的图像 1,2 Repairing Paint Brush Bristles: 步骤 9 中的图像 2,2
    • Cut off excess frayed bristles (optional).
    • There may be a few fraying bristles left. These are harmless and will cling to the brush shape when dipped in paint.
    • If preferred, you may use a nail clipper to cut these hairs off.
结论
Your brushes should now be usable again. Unfortunately this cannot be done too many times because the turpentine will start to damage the bristles, so make sure to regularly wash your brushes.
23等其他人完成本指南。
Ankita Bhowmik
于09/29/15注册
659 声望
撰写一个指南
团队
Cal Poly, Team 15-7, Green Fall 2015 Cal Poly, Team 15-7, Green Fall 2015 的会员
CPSU-GREEN-F15S15G7
3 名成员
创作了7篇指南
6条评论
Is this only for synthetic brushes? What about natural hair brushes which are frayed?
radhikacr999 - 回复
Hey! Can you tell me what is the use of wrapping the bristles in aluminium foil?
Santwana Verma - 回复
The article literally says “to retain the brush shape”
Paul Peddie -
I’ve seen other tutorials say to mix vinegar with the boiled water, would you recommend it?
John Ippoliti - 回复
Awesome guide, By the way, this guide "Can You Spray Stain With An Airless Sprayer" also contain useful information.
Muhammad Usman Bhatti - 回复
添加评论
浏览统计数据:
过去 24 小时: 27
过去 7 天: 168
过去 30 天: 757
总计 139,501
