简介
My system had fallen from a shelf and then the front corner were the Antenna sits was damaged. It caused a wire to break at the solder point on the antenna. It caused input lag and you had to be right in-front of the system. Literally direct line of site . The controller would work for a minute then lag out. The X button wouldn't work or anything. How I fixed it could also fix a factory defect if the antenna wasn't put together right.
你所需要的
Use the tip of a spudger to disconnect the antenna cable from the motherboard.
As you can see there are 2 solder points . the wire must run through the first point to the second point. But when the system fell it broke that connection and Antenna got bent. If at factory the solder points were not correct it will cause the same lag issue with controller and WiFi.
This is the easy part. Remove the antenna. Move the wire inbetween the two solder points so it is connecting to the second point. Once there take your soldering Iron and heat up the solder and drag it over the wire to make the connection.
Just remember to leave the gap here. Do not bend the antenna to make the points touch your self. The gap that runs through it is there by design and changing that has adverse effects on controller and WiFi . But its that easy. My PS4 now works fine with controller and WiFi . No need for further tear-down and extra parts. Put bottom on. GTGo
36等其他人完成本指南。
38条评论
My console was giving me the same problem aft lots of research i came across ur guide and today i fixed the wifi antenna and its working awesome Thanks alot
Me podrías compartir la guía?
Could you share the guide?
I replaced my antenna with a new one. But im still experiencing input lag. What else should I do?
angellom90 - 回复
