跳转到主内容
Repairing Nokia Lumia 520 Power Button
你所需要的
  1. Repairing Nokia Lumia 520 Power Button, Repairing Nokia Lumia 520 Power Button: 步骤 1 中的图像 1,1
    • Remove the back cover from the phone.
    • Take a bus ticket or anything else that has a thickness of 0.5-0.6 mm.
    • Cut the ticket to form a triangle.
    • Insert the triangle in the gap between the button and the chassis.
    • Cut the part of the ticket that is out of the chassis.
    • Now with a paper clip tests if it works.
    • If it works remount the back cover. If i doesn't work probably the problem is the button and not the contact and you need to replace it.
结论
6等其他人完成本指南。
keroro90
于08/07/14注册
213 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,848
