跳转到主内容
Repairing Nokia 6500 Slide LCD
你所需要的
  1. Repairing Nokia 6500 Slide LCD, LCD: 步骤 1 中的图像 1,3 Repairing Nokia 6500 Slide LCD, LCD: 步骤 1 中的图像 2,3 Repairing Nokia 6500 Slide LCD, LCD: 步骤 1 中的图像 3,3
    • Press the eject button to open battery enclosure. Remove battery, sim card and micro sd card.
  2. Repairing Nokia 6500 Slide LCD: 步骤 2 中的图像 1,1
    • Remove four screws using torx 5 screwdriver.
  3. Repairing Nokia 6500 Slide LCD: 步骤 3 中的图像 1,3 Repairing Nokia 6500 Slide LCD: 步骤 3 中的图像 2,3 Repairing Nokia 6500 Slide LCD: 步骤 3 中的图像 3,3
    • Pry each side evenly around its edges. The phone should start to split into two halves.
  4. Repairing Nokia 6500 Slide LCD: 步骤 4 中的图像 1,2 Repairing Nokia 6500 Slide LCD: 步骤 4 中的图像 2,2
    • The top and bottom half of the phone is still connected by two ribbon connectors each side. Use a thin plastic like a credit card to carefully disconnect it.
  5. Repairing Nokia 6500 Slide LCD: 步骤 5 中的图像 1,1
    • Make sure all components stay on each side (see picture).
  6. Repairing Nokia 6500 Slide LCD: 步骤 6 中的图像 1,2 Repairing Nokia 6500 Slide LCD: 步骤 6 中的图像 2,2
    • Pull the black part away from the rest of the phone in the direction shown by the white arrows follows by the blue.
    • This way you can accessing the two screws at the bottom of the phone. Remove four srews using torx 5 screwdriver.
  7. Repairing Nokia 6500 Slide LCD: 步骤 7 中的图像 1,2 Repairing Nokia 6500 Slide LCD: 步骤 7 中的图像 2,2
    • Carefully pry out the lcd cover.
    • Make sure the board connector pass the cover by angle.
  8. Repairing Nokia 6500 Slide LCD: 步骤 8 中的图像 1,3 Repairing Nokia 6500 Slide LCD: 步骤 8 中的图像 2,3 Repairing Nokia 6500 Slide LCD: 步骤 8 中的图像 3,3
    • Disconnect the LCD connector.
    • Carefully peel the ribbon away from the back of the screen. It's held in place with double sided tape.
    • The LCD screen will now be loose and can be removed and replace with the new one.
结论
另外一个人完成了本指南。
dwi
于07/02/13注册
163 声望
撰写一个指南
2条评论
Great - have screen in. Now, have you ever replaced the port / jack for the charger? Mine will not accept the prong all of a sudden
Brenda Kent - 回复
Got new charger port in 2017, now the battery goes - tried several batteries - and tried them in other phones and are fine - thinking something shorting or draining it in the phone?
Brenda Kent - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 4,129
