跳转到主内容
Repairing Nintendo 64 Audio Video Port
你所需要的
  1. Repairing Nintendo 64 Audio Video Port, Repairing Nintendo 64 Audio Video Port: 步骤 1 中的图像 1,1
    • Open the Nintendo 64 in order to operate on the motherboard. Steps to open it can be found here.
  2. Repairing Nintendo 64 Audio Video Port: 步骤 2 中的图像 1,1
    • Locate the audio/video connections at the rear right area of the motherboard. There should be six bent strips of gold metal connecting to the motherboard. For unrestricted access to the A/V area, remove the plastic plate above it by unscrewing the left and right screws. After unscrewing, lift the motherboard a bit in order to pull the plate off.
  3. Repairing Nintendo 64 Audio Video Port: 步骤 3 中的图像 1,2 Repairing Nintendo 64 Audio Video Port: 步骤 3 中的图像 2,2
    • Heat up the small contact (between each strip and the motherboard) with a soldering iron. For best results, heat all 6 contact points so that they become soft and moldable, and then allow them to dry and reform a solid connection.
    • Heating it and letting it reform will potentially fix any oxidation which could prevent the flow of electricity, so let the contact reform and dry, and then reattach the plate onto the 6-prong area. Test the output for correct video signal and/or audio signal (depending on which problem was occurring).
结论
9等其他人完成本指南。
4条评论
Un grand merci, grâce à vous ma N64 re-fonctionne !
Edocle - 回复
Excellent guide! Repaired my brothers N64 in one shot. Make sure you have lots of screw holders there's like 8 different types of screws.
C Parker - 回复
Wow- it worked thank you!!!
De Lixer - 回复
Any recommendations for corrosion of the gold metal strips? I have cleaned them off as much as possible but some of them are badly damaged. Can they be repaired or replaced?
J Miller - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 26
过去 30 天: 171
总计 26,951
