跳转到主内容
Repairing Minolta Dimage Xt Lens Cover
你所需要的
  1. Repairing Minolta Dimage Xt Lens Cover, Casing: 步骤 1 中的图像 1,3 Repairing Minolta Dimage Xt Lens Cover, Casing: 步骤 1 中的图像 2,3 Repairing Minolta Dimage Xt Lens Cover, Casing: 步骤 1 中的图像 3,3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Repairing Minolta Dimage Xt Lens Cover: 步骤 2 中的图像 1,3 Repairing Minolta Dimage Xt Lens Cover: 步骤 2 中的图像 2,3 Repairing Minolta Dimage Xt Lens Cover: 步骤 2 中的图像 3,3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Repairing Minolta Dimage Xt Lens Cover, Lens Cover: 步骤 3 中的图像 1,1
    • Place the internal electronics face-up. Look at the side with the flash turned towards you.
    • The lens cover is a small sheet of metal that rests directly infront of the lens when the camera is turned off.
    • Check to see if the spring action arm (what the yellow arrow is pointing to) is attached to the lens cover with the small knob in the corner (circled in yellow).
  4. Repairing Minolta Dimage Xt Lens Cover: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • If the arm is not attached (as shown in the previous), use tweezers to place the arm over the knob on the lens cover.
    • Inside the yellow circle, the arm is in the correct position.
结论
Reassemble the casing by reversing steps 1 and 2.
Megan Milam
于03/11/13注册
28 声望
创作了5篇指南
团队
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 的会员
CLEM-BENSON-S13S12G4
3 名成员
创作了14篇指南
一条评论
In Bild 3 ist der gelbe Kreis falsch gesetzt: der kleine Knopf ist unten links an der Blende, wie in Bild 4 positioniert. hr
Hubert Rieping - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 1,003
