跳转到主内容
Repairing Kenwood KDC-X590 Blank Faceplate Resistors
你所需要的
  1. Repairing Kenwood KDC-X590 Blank Faceplate Resistors, Repairing Kenwood KDC-X590 Blank Faceplate Resistors: 步骤 1 中的图像 1,1
    • Sorry for not including a complete tear down but I have no other images of this work.
    • Due to temperature changes in the car the solder will crack on this model and possibly others close to it causing the faceplate to no longer display. After unscrewing the housing and removing the cd unit locate the 10 surface mount resistors marked r27 shown in red.
    • Using a small tip soldering iron reflow the solder on each edge of the resistor. You should not need to add any extra but in my case I did for a few.
    • After all 20 contacts have been reflowed to the 10 resistors reattach the cd drive and case.
    • Enjoy your display like it was new again!
结论
2等其他人完成本指南。
ej e
于02/21/14注册
177 声望
撰写一个指南
一条评论
quick note: most of these connect to eachother via the PCB, so the close together ones can be soldered directly together for ease. I succeeded in fixing my stereo's faceplate!
jbudorg - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 5,385
