跳转到主内容
加入维修社区 - 创建账户
Repairing Internet Explorer Crashes
  1. Repairing Internet Explorer Crashes, Restore Advanced Application Settings: 步骤 1 中的图像 1,1
    • Restore the advanced application settings including the ActiveX Filtering and dialog Pop-Up box settings. You’ll be prompted to remove the personal configurations as well. Check-up that box in order to successfully restore all the settings.
    • Close all other applications and open Internet Explorer.
    • Click Tools -> Internet Options.
    • Click Reset button after checking-up the “Delete personal settings” checkbox.
  2. Repairing Internet Explorer Crashes, Filter Malfunctioning Extensions: 步骤 2 中的图像 1,1
    • Filter the malfunctioning extensions. Disable all the extensions which are not functioning properly. The list of all extensions is displayed in a dialog box after performing the steps given below:
    • First show the menu bar by pressing the Alt key of your keyboard.
    • Click Tools -> Manage Add-Ons.
    • Set Show -> All add-ons.
    • Filter unwanted extensions including those not working properly.
  3. Repairing Internet Explorer Crashes, Check Internet DNS Configs: 步骤 3 中的图像 1,1
    • The Internet DNS Configurations might have been changed. Incorrect DNS configurations are one of the reasons behind this issue.
    • Press the Windows Key and X keys simultaneously, and then select the Command Prompt (Admin).
    • Type below commands one by one and press ENTER at the end of each command: • ipconfig /flushdns • ipconfig /registerdns • ipconfig /release
    • Exit Command Prompt and then reboot your PC.
    • A Troubleshooter tool automatically detects and repairs the Internet Explorer crashes problem. All you’ve to do is-
    • Download the tool called ZombieSoftFix.
    • Install the program on your PC.
    • Follow the on-screen instructions until your problem is completely fixed.
  4. Repairing Internet Explorer Crashes, Uninstall & Reinstall it again: 步骤 5 中的图像 1,1
    • Some IE files can be corrupt. Uninstalling and reinstalling the same will fix the issue.
    • Insert the Windows OS disc.
    • Press Windows Key and X simultaneously.
    • Click Programs and Features -> Turn Windows features on or off.
    • Uninstall IE and reinstall it again. A system reboot requires.
结论
9等其他人完成本指南。
VikasMedhekar
于12/10/14注册
938 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 44
总计 2,300
