跳转到主内容
Repairing Hungry Cat Savings Bank Gear
你所需要的
  1. Repairing Hungry Cat Savings Bank Gear, Repairing Hungry Cat Savings Bank Gear: 步骤 1 中的图像 1,1
    • Turn the Hungry Cat Savings Bank off.
    • Using a coin, remove the cap covering the change storage.
    • Use a standard Phillips screwdriver #0 to remove the screw holding the battery cover in place.
  2. Repairing Hungry Cat Savings Bank Gear: 步骤 2 中的图像 1,1
    • Empty all change from the Hungry Cat Savings Bank, or it will drive you bonkers during repair.
  3. Repairing Hungry Cat Savings Bank Gear: 步骤 3 中的图像 1,1
    • Remove the battery cover and batteries.
  4. Repairing Hungry Cat Savings Bank Gear: 步骤 4 中的图像 1,1
    • Remove the four screws holding the cover in place. You'll need a traditional Phillips screwdriver, not a screwdriver set, to reach fully into the wells.
  5. Repairing Hungry Cat Savings Bank Gear: 步骤 5 中的图像 1,1
    • Turn over savings bank and slide case up. You might need to grab the base to pull it apart.
  6. Repairing Hungry Cat Savings Bank Gear: 步骤 6 中的图像 1,1
    • Locate the jam. You might need to temporarily put in the batteries to activate the arm, so you can find the jam.
  7. Repairing Hungry Cat Savings Bank Gear: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the coin using a set of tweezers.
    • Reassemble the device and enjoy your working Hungry Cat Savings Bank!
结论
To reassemble your device, follow these instructions in reverse order. Make sure to remove the batteries before reassembling.
6等其他人完成本指南。
团队
Ethical Culture Fieldston School Ethical Culture Fieldston School 的会员
Business
3 名成员
创作了2篇指南
6条评论
Hi, my motor burned out, where could I get a replacement?
Krill - 回复
My one will not stop once it has grabbed a coin , the paw keeps coming out and it has to be turned off at the switch. And he doesn't meow anymore.
michael.tulley - 回复
I don’t have my box in front of me, but it sounds like the tray isn’t returning to the rest position fully. When you disassemble it, is there anything preventing the tray (where you put the quarter) from smoothly returning to rest position?
Jeannie Crowley -
How to you repair the Godzilla bank? Bought one yesterday and it completely stopped working?
divineangel1952 - 回复
Is there any sound at all coming from the bank or is it completely silent when you press the button?
Jeannie Crowley -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 25
总计 6,322
