跳转到主内容
Repairing HP Photosmart D110a Paper Jam
  1. Repairing HP Photosmart D110a Paper Jam, Repairing HP Photosmart D110a Paper Jam: 步骤 1 中的图像 1,1
    • Identify the location where the piece of paper is jammed.
  2. Repairing HP Photosmart D110a Paper Jam: 步骤 2 中的图像 1,3 Repairing HP Photosmart D110a Paper Jam: 步骤 2 中的图像 2,3 Repairing HP Photosmart D110a Paper Jam: 步骤 2 中的图像 3,3
    • Use your hand to gently remove the jammed paper.
    • Pull the paper until it is completely removed from the printer.
  3. Repairing HP Photosmart D110a Paper Jam: 步骤 3 中的图像 1,1
    • Dispose of paper that caused the jam. Replace the jammed paper with fresh, unwrinkled paper.
终点
Tim Wise
于04/01/11注册
173 声望
创作了7篇指南
团队
Cal Poly, Team 10-38, Forte Spring 2011 Cal Poly, Team 10-38, Forte Spring 2011 的会员
CPSU-FORTE-S11S10G38
5 名成员
创作了10篇指南
3条评论
my printer is jamming overtime I try to print something. I have cleared paper jams from both the front and back, and it’s still doing it. Any ideas?
Lissa barrett - 回复
My D110a printer sometimes does this depending on the paper thickness. Thin paper jams more than thick paper, so I suspect that the rollers are getting slick and cannot grab the paper. I will try to open my own unit and see if they can be cleaned or recondition to eliminate the problem. I will post again if I can fix it!
raymondjram -
The paper can be removed from the rear. The roller cover is removed by puling out the cover on the left side (as seen from the rear) and slides toward the left. The paper ca n be grabbed by hand. To replace the cover, slide the two plastic pins inward toward the right until they catch, then push the cover back from the left side.
raymondjram - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 21
总计 4,799
