当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Remove the 6 outer screws on the underside of the laptop.
Open the battery compartment and remove the 7 visible screws.
Pry the corners of the bezel at the base of the keyboard, pushing up until it loosens.
Carefully remove the ribbon connections of the keyboard, power button, and wifi button.
Disconnect and re-connect the white monitor ribbon located on the left side to make sure it sits firmly in the connection.
Reassemble the laptop by following these steps in reverse.
The monitor should work when powered on again.
9等其他人完成本指南。
