跳转到主内容
Repairing Cup Holder for 2008 328i BMW
你所需要的
  1. Repairing Cup Holder for 2008 328i BMW, Repairing Cup Holder for 2008 328i BMW: 步骤 1 中的图像 1,3 Repairing Cup Holder for 2008 328i BMW, Repairing Cup Holder for 2008 328i BMW: 步骤 1 中的图像 2,3 Repairing Cup Holder for 2008 328i BMW, Repairing Cup Holder for 2008 328i BMW: 步骤 1 中的图像 3,3
    • Apply putty knife to edge of cover until it pops open
    • Remove screws off of broken cup holder
    • Take cup holder out
  2. Repairing Cup Holder for 2008 328i BMW: 步骤 2 中的图像 1,3 Repairing Cup Holder for 2008 328i BMW: 步骤 2 中的图像 2,3 Repairing Cup Holder for 2008 328i BMW: 步骤 2 中的图像 3,3
    • Remove plastic cover on cup holder by pulling apart where the lips meet
    • Locate spring in device
  3. Repairing Cup Holder for 2008 328i BMW: 步骤 3 中的图像 1,2 Repairing Cup Holder for 2008 328i BMW: 步骤 3 中的图像 2,2
    • Fully take apart the cup holder to get to the inside of the cup holder
    • Locate where spring is placed
  4. Repairing Cup Holder for 2008 328i BMW: 步骤 4 中的图像 1,3 Repairing Cup Holder for 2008 328i BMW: 步骤 4 中的图像 2,3 Repairing Cup Holder for 2008 328i BMW: 步骤 4 中的图像 3,3
    • Locate where the spring connects
    • If hole is not broken then just apply spring into hole
    • If the hole broke, like in this case here, then drill a hole the size of the spring around the same spot of the other hole
    • Caution: Be careful drilling the hole, the plastic is slippery when in contact with drill bit
  5. Repairing Cup Holder for 2008 328i BMW: 步骤 5 中的图像 1,3 Repairing Cup Holder for 2008 328i BMW: 步骤 5 中的图像 2,3 Repairing Cup Holder for 2008 328i BMW: 步骤 5 中的图像 3,3
    • Test to make sure spring is properly working
    • Reassemble the cup holder
  6. Repairing Cup Holder for 2008 328i BMW: 步骤 6 中的图像 1,3 Repairing Cup Holder for 2008 328i BMW: 步骤 6 中的图像 2,3 Repairing Cup Holder for 2008 328i BMW: 步骤 6 中的图像 3,3
    • Put cup holder back in place
    • Screw in screws
  7. Repairing Cup Holder for 2008 328i BMW: 步骤 7 中的图像 1,1
    • Check to make sure cup holder works
    • Start to put on cover by lining up holes
  8. Repairing Cup Holder for 2008 328i BMW: 步骤 8 中的图像 1,3 Repairing Cup Holder for 2008 328i BMW: 步骤 8 中的图像 2,3 Repairing Cup Holder for 2008 328i BMW: 步骤 8 中的图像 3,3
    • Press firmly on cover all around until it is fully on
  9. Repairing Cup Holder for 2008 328i BMW: 步骤 9 中的图像 1,2 Repairing Cup Holder for 2008 328i BMW: 步骤 9 中的图像 2,2
    • Enjoy your fixed cup holder!
结论
Follow these steps step by step to get your broken cup holder fixed.
18等其他人完成本指南。
Michael Tapia
于09/29/15注册
499 声望
撰写一个指南
团队
Cal Poly, Team 15-5, Green Fall 2015 Cal Poly, Team 15-5, Green Fall 2015 的会员
CPSU-GREEN-F15S15G5
4 名成员
创作了14篇指南
6条评论
Easy fix that saved over $60 if I had to purchase a new part and much much more if the the dealer were to have fixed this. Thank you
Keith La Plain - 回复
clever idea when plastic holding the spring hook is broken. nice hack of a fix.
Nicholas McKoy - 回复
Is there any way to purchase just the spring? In my case the plastic is fine, it’s the shaped metal tip of the spring that sheared off somehow!? I also need the tentioner.
Ryan Cornell - 回复
This happened to me as well. I broke off the end of the coil/spring while bending to make a “hook” shape.
I looked for purchasing just the spring, but could not find it. Next up was the entire cupholder apparatus, either used ($~26), URO ($~39), or OEM/genuine BMW ($60-75+). This isn’t cheap and is not actually necessary to buy anything ,though.
Much easier is what I did instead, which was taking advantage of the coil material’s rigid/”easily-snap-off-able” property to make a new (wider) hook. I pulled the snapped end of the coil out a little, then put in a thin screwdriver to kind of hold the coil out extended. Next I used flat nose pliers to hold the end flat, while using long nose pliers to break off a new gap on both sides, effectively making a new “t” end. Then of course I VERY GENTLY bent it around to make a “hook”. I gently clipped the new spring hook into the preexisting plastic hole. It works for new after reinstalling. We’ll see how it holds up!
Benjamin Castellon -
Dealer wanted $180. Flat spring has T on end and locks into corresponding T in plastic. My plastic was broken out on one side. I merely took a bit in my dremel, and made the old T deeper in order to catch the metal end.
Larry Pockras - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 58
总计 26,715
