当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
First you need to remove the back cover of the camera, so that you can access the motherboard. Here is how it looks like with the backcover removed (4 scew removed for a powershot A1200). At the top, you can see the main pins connecting the battery contact to the motheboard, but it is difficult to access them.
这个步骤还没有翻译 帮忙翻译一下
Then, i remove the screen (2 screws), so that the motherboard and the connecting pins are easylly accessible.
In the second picture, you can see that near the pins, there is a "+" and a "-" sign. Here, by gently pressing them with a screwdriver, I noticed that one of them was completly loose. That is the reason of the problem.
Then, it is simple to fix it by soldering the loose connection.
The problems comes from the fact that the battery pins are directly solded to the motherboard, therefore the force exerted to maintain the good contact with the battery is applied to the soldering, which may eventually brake.
2等其他人完成本指南。
