跳转到主内容
Repairing Buttons on Casio fx-300ES Calculator
你所需要的
  1. Repairing Buttons on Casio fx-300ES Calculator, Repairing Buttons on Casio fx-300ES Calculator: 步骤 1 中的图像 1,2 Repairing Buttons on Casio fx-300ES Calculator, Repairing Buttons on Casio fx-300ES Calculator: 步骤 1 中的图像 2,2
    • Remove the six 5 mm screws on the back of the calculator.
  2. Repairing Buttons on Casio fx-300ES Calculator: 步骤 2 中的图像 1,2 Repairing Buttons on Casio fx-300ES Calculator: 步骤 2 中的图像 2,2
    • Carefully remove the back plate to reveal the circuit board and the battery.
  3. Repairing Buttons on Casio fx-300ES Calculator: 步骤 3 中的图像 1,3 Repairing Buttons on Casio fx-300ES Calculator: 步骤 3 中的图像 2,3 Repairing Buttons on Casio fx-300ES Calculator: 步骤 3 中的图像 3,3
    • Remove the four 4 mm screws from the circuit board.
  4. Repairing Buttons on Casio fx-300ES Calculator: 步骤 4 中的图像 1,1
    • Be aware of the placement of the blue, black, red, and yellow wires because they will fall out when the next step is taken.
  5. Repairing Buttons on Casio fx-300ES Calculator: 步骤 5 中的图像 1,3 Repairing Buttons on Casio fx-300ES Calculator: 步骤 5 中的图像 2,3 Repairing Buttons on Casio fx-300ES Calculator: 步骤 5 中的图像 3,3
    • Carefully lift the circuit board while leaving the grey rubber piece face down.
    • Simply flip the circuit board and the screen over but do not remove them fully.
    • Make sure the calculator is face down.
    • Buttons are loose do not flip calculator over.
  6. Repairing Buttons on Casio fx-300ES Calculator: 步骤 6 中的图像 1,3 Repairing Buttons on Casio fx-300ES Calculator: 步骤 6 中的图像 2,3 Repairing Buttons on Casio fx-300ES Calculator: 步骤 6 中的图像 3,3
    • Now lift the grey rubber piece off to reveal the individual buttons.
    • Buttons are loose make sure they do not come off with the rubber piece.
  7. Repairing Buttons on Casio fx-300ES Calculator: 步骤 7 中的图像 1,3 Repairing Buttons on Casio fx-300ES Calculator: 步骤 7 中的图像 2,3 Repairing Buttons on Casio fx-300ES Calculator: 步骤 7 中的图像 3,3
    • To remove the buttons you can use your screwdriver and lightly flip them out of their individual spaces.
    • You can now access all the buttons and make any alterations needed.
  8. Repairing Buttons on Casio fx-300ES Calculator: 步骤 8 中的图像 1,1
    • Refer to this picture if any buttons get misplaced or fall out.
结论
4等其他人完成本指南。
团队
Cal Poly, Team 28-2, Green Spring 2015 Cal Poly, Team 28-2, Green Spring 2015 的会员
CPSU-GREEN-S15S28G2
4 名成员
创作了2篇指南
5指南评论
Great photos make sure to replace the stock photos with those you take. Maybe retake photos with white background.
Kathryn Webb - 回复
my answer key button not working. when i press button it shows the X10 so what can i do plzz give tips for repairing
ayush shukla - 回复
Halp my board is stuck to the front plate sith super glue from previous owner.
[deleted] - 回复
I repaired my Casio fx-300w, a similar calculator with similar buttons. My mother, who gave it to me, spilled coffee once when using it in her office. I got rid of the sticky coffee gunk formed nearly 12 years ago.
Matthew Yang - 回复
وقعت حاسبتي من نوع كازيو على الارض فلم تشتغل بالرغم من انها لم تنكسر وقد اشتريتها قبل شهرين من فضلكم ساعدوني ماذا افعل؟
abir abir - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 56
总计 26,098
