简介
VOIP had Failed, after researching on the internet I found a forum page which gave a fix for a similar model. Replacing 2 capacitors fixed the VOIP
你所需要的
Turning the Router over you find 4 rubber feet hiding 4 Philips head screws.
Remove the screws and turn the router back upright.
The top of the case should now lift off.
The C928 Capacitor 100uF 25v is the one talked about in the forum mentioned in the intro.
While I was checking the solder side of the board I noticed there was a bad solder joint on this cap. You cant see it at this resolution though.
While checking the state of the other caps on the board I noticed that this one 1000uF 10v was also showing signs of heat stress.
Both capacitors were replaced.
You can see the new caps in position on the right.
For the princely sum AU $1.20 in parts, 20 mins setting up, 5 mins to fix, 5 mins to put it all away I have saved myself aprox $200 for a new VOIP router :)
2等其他人完成本指南。
2指南评论
Champion!
Thanks for this.
$1.30 in parts saved me going out buying a new VOIP adapter.
No worries, Glad it helped :)
