跳转到主内容
加入维修社区 - 创建账户
Repairing Apple Wireless Keyboard Power Button
你所需要的
    1. Repairing Apple Wireless Keyboard Power Button, Power Button: 步骤 1 中的图像 1,1
      • Cut away the dented aluminum with your cutting knife. It's a little bit tricky and you have to use some force to cut it, but it will work.
      • Please be carefull with the knife! You can cut into your thumb very easily!
      添加评论
    2. Repairing Apple Wireless Keyboard Power Button: 步骤 2 中的图像 1,1
      • Carefully pull out the power button if needed and correct the dent
      • Push the power button back in once the dent is smoothed out from inside.
      添加评论
结论
Once the aluminum that was holding the button in is cut away, your device is repaired. No reassembly is necessary.
取消:我没有完成这个指南。
58等其他人完成本指南。
Peter Alt
于06/11/10注册
859 声望
撰写一个指南
28指南评论
This worked for me. Be Careful. I made it worse initially because the inside edge became rough with my hacking away. I ended up smoothing the edge with a stainless steel cuticle pusher. Also: Constantly blow the scrapings away so they don't get caught between the button and the edge.
joan roco - 回复 分享
Thanks for this idea. It worked great for me and saved the keyboard. My first idea was to try to fully disassemble the keyboard so I could bend the piece back out with pliers after removing the button. I probably would've destroyed the keyboard without fixing it without this simple idea.
Wesley Womack - 回复 分享
Bullshit nothing can go between the button and the Keyboard, i just break my keyboard... thx
ruedifly - 回复 分享
It worked for me. Took an hour or so to carefully cut the alumunium around the button. It took quite long because I have a crappy cutter that will easily snapped its sharp point.
Eventually the click was starting to work. Didn't manage to cut deeper so the whole assembly is still stuck.
Indramin Darmadi - 回复 分享
It worked! The dent is pressing the power button making it unmovable. Its was on that state until I changed batteries. Now scratched and dented but working. Apple design flaw.
adelacuesta2972 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 32
过去 30 天: 120
总计 76,092
