跳转到主内容
Repairing Alarm Clock Clock Projector
你所需要的
  1. Repairing Alarm Clock Clock Projector, The issue: 步骤 1 中的图像 1,1
    • The Problem: here I should read 12:47
  2. Repairing Alarm Clock Clock Projector: 步骤 2 中的图像 1,2 Repairing Alarm Clock Clock Projector: 步骤 2 中的图像 2,2
    • After removing the 2 screws on the bottom, carefully open the bottom frame, see location of the plastic snaps snaps
  3. Repairing Alarm Clock Clock Projector: 步骤 3 中的图像 1,3 Repairing Alarm Clock Clock Projector: 步骤 3 中的图像 2,3 Repairing Alarm Clock Clock Projector: 步骤 3 中的图像 3,3
    • Removes the back panel, taking care of the other plastic snaps
    • The projector and its optics is shown in the blue square
  4. Repairing Alarm Clock Clock Projector, The optics: 步骤 4 中的图像 1,3 Repairing Alarm Clock Clock Projector, The optics: 步骤 4 中的图像 2,3 Repairing Alarm Clock Clock Projector, The optics: 步骤 4 中的图像 3,3
    • cables are tied together with a simple ribbon, in general the inner construction seems very cheap
    • The Projector is made of three parts:
    • A red LED
    • The display with its controller
    • the lens with focus mechanics
    • All parts are kept by tiny screws that you have to remove
    • Take extra caution when handling the display, the flat cable is very weak and can be damaged by improper handling
  5. Repairing Alarm Clock Clock Projector: 步骤 5 中的图像 1,3 Repairing Alarm Clock Clock Projector: 步骤 5 中的图像 2,3 Repairing Alarm Clock Clock Projector: 步骤 5 中的图像 3,3
    • Carefully remove display from its supporting frame
    • The issue should be ralated to flat cable connecting display to controller
  6. Repairing Alarm Clock Clock Projector: 步骤 6 中的图像 1,3 Repairing Alarm Clock Clock Projector: 步骤 6 中的图像 2,3 Repairing Alarm Clock Clock Projector: 步骤 6 中的图像 3,3
    • Verify that moving the flat the display returns to work
    • put a stiffner on controller side and close to the display
    • if everything is working, reassemble the clock by doing the steps in reverse order
  7. Repairing Alarm Clock Clock Projector: 步骤 7 中的图像 1,1
    • Problem solved.
结论
6等其他人完成本指南。
Andrea Gangemi
于04/26/15注册
172 声望
撰写一个指南
6指南评论
The clock projection displays only partial numbers.one number is missing. The face on the clock displays perfect. It's just The projection on the wall that's missing a digit
eacoch - 回复
my Peakeep clock keeps the correct time but you can't see the time clearly. It's as if the light is turned off.
serena williams - 回复
Thank you for this post! It was the exact starting point to fix my projection clock which was looking dull and had lost a few segments. While the addition of supporting tape helped for a short period, doing it again in conjunction with Step 6 of the following link (http://www.instructables.com/id/How-to-r...) - Applying heat - to the ribbon contact points was the ticket that restored my projection clock functionality.
Adam - 回复
Hi Adam, glad to helped you
Andrea Gangemi -
The display on my clock is missing parts of a number but project correct time , help ?
mandzb87 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 79
总计 13,498
