跳转到主内容
Repairing Acer Aspire 5100 Display Screen
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Repairing Acer Aspire 5100 Display Screen, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is turned off and unplugged.
    • Flip the laptop over so the audio jacks are facing you.
    • Unlock the battery by sliding the button (located above the battery) towards the outer edge of the computer. When you feel the battery release and pop up, gently pull the battery from its compartment.
  2. Repairing Acer Aspire 5100 Display Screen, Display Screen: 步骤 2 中的图像 1,1
    • Flip the laptop back over and open it.
  3. Repairing Acer Aspire 5100 Display Screen: 步骤 3 中的图像 1,1
    • Pry out the 4 screw covers with a dental pick or other small pointed tool, and remove the screws located beneath them.
  4. Repairing Acer Aspire 5100 Display Screen: 步骤 4 中的图像 1,2 Repairing Acer Aspire 5100 Display Screen: 步骤 4 中的图像 2,2
    • Use a plastic spudger to carefully pry the front bezel off.
    • The bezel will tend to "snap" off little by little, as you work around it, don't be afraid to use a little force.
  5. Repairing Acer Aspire 5100 Display Screen: 步骤 5 中的图像 1,1
    • Now remove the top cover by unscrewing the two Phillips #0 screws found at the bottom of the panel.
    • You are removing the cover behind the LCD, not the LCD screen. The two screws are the only thing holding it so carefully support it so it does not pull on and damage any cables.
  6. Repairing Acer Aspire 5100 Display Screen: 步骤 6 中的图像 1,1
    • Unplug the display data cable attached to the back of the LCD.
    • Do not touch this area,it destroys the backlight!
  7. Repairing Acer Aspire 5100 Display Screen: 步骤 7 中的图像 1,1
    • Finally, remove the LCD screen by unscrewing the six screws connecting the LCD panel to the side frame.
结论
3等其他人完成本指南。
iDeleted
于07/07/10注册
2,101 声望
创作了39篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 4,154
