跳转到主内容
Repair Redragon S107 Unresponsive Keys
你所需要的
  1. Repair Redragon S107 Unresponsive Keys, Repair Redragon S107 Unresponsive Keys: 步骤 1 中的图像 1,1
    • Unplug the USB cable to prevent issues during the repair.
  2. Repair Redragon S107 Unresponsive Keys: 步骤 2 中的图像 1,2 Repair Redragon S107 Unresponsive Keys: 步骤 2 中的图像 2,2
    • Remove all 13 Phillips screws located on the underside of the keyboard and gently remove the casing.
  3. Repair Redragon S107 Unresponsive Keys: 步骤 3 中的图像 1,1
    • Lay the RGB LED panel flat on the desk.
    • Make sure that you do not damage the black wire on the left corner of the keyboard connected to the LED panel.
  4. Repair Redragon S107 Unresponsive Keys: 步骤 4 中的图像 1,2 Repair Redragon S107 Unresponsive Keys: 步骤 4 中的图像 2,2
    • Remove the three screws on the metal bracket located towards the top left on the keyboard.
    • Remove the rubber underneath the metal bar.
  5. Repair Redragon S107 Unresponsive Keys: 步骤 5 中的图像 1,2 Repair Redragon S107 Unresponsive Keys: 步骤 5 中的图像 2,2
    • Use a cotton swab and add isopropyl alcohol to thoroughly clean the green membrane sheet and place the green membrane back onto the key switches.
  6. Repair Redragon S107 Unresponsive Keys: 步骤 6 中的图像 1,3 Repair Redragon S107 Unresponsive Keys: 步骤 6 中的图像 2,3 Repair Redragon S107 Unresponsive Keys: 步骤 6 中的图像 3,3
    • Use electrical tape to fix each contact strip that connects the green membrane to the motherboard into place.
    • Align the contact strips in place with the black lined traces provided on the motherboard.
  7. Repair Redragon S107 Unresponsive Keys: 步骤 7 中的图像 1,3 Repair Redragon S107 Unresponsive Keys: 步骤 7 中的图像 2,3 Repair Redragon S107 Unresponsive Keys: 步骤 7 中的图像 3,3
    • Place the rubber and metal bar back into place. Reinstall the three screws tightly as this will ensure no complications with the alignment of contact strips.
  8. Repair Redragon S107 Unresponsive Keys: 步骤 8 中的图像 1,2 Repair Redragon S107 Unresponsive Keys: 步骤 8 中的图像 2,2
    • Place the RGB LED panel back onto the green membrane sheet. Reinstall the casing.
结论
另外一个人完成了本指南。
Usman Khan
于01/18/23注册
430 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 64
总计 655
