跳转到主内容
Repair Guide for the LG Net10
你所需要的
  1. Repair Guide for the LG Net10, Complete disassembling of the phone to get to the motherboard: 步骤 1 中的图像 1,2 Repair Guide for the LG Net10, Complete disassembling of the phone to get to the motherboard: 步骤 1 中的图像 2,2
    • Frontal view and rear view of the LG Net10 prior to disassembling.
  2. Repair Guide for the LG Net10: 步骤 2 中的图像 1,2 Repair Guide for the LG Net10: 步骤 2 中的图像 2,2
    • Remove battery back cover by applying pressure along the groove. The LG logo should be up right. Apply the pressure downwards to remove the cover.
  3. Repair Guide for the LG Net10: 步骤 3 中的图像 1,2 Repair Guide for the LG Net10: 步骤 3 中的图像 2,2
    • Remove the battery from the top of the battery.
  4. Repair Guide for the LG Net10: 步骤 4 中的图像 1,1
    • Remove the SIM card, by pushing down on the top of the SIM card and sliding it out from under the metal band.
  5. Repair Guide for the LG Net10: 步骤 5 中的图像 1,2 Repair Guide for the LG Net10: 步骤 5 中的图像 2,2
    • Remove all four screws from the back of the phone by using a small Phillips head screwdriver and turning it counterclockwise.
    • The screws are 0.5 centimeters.
  6. Repair Guide for the LG Net10: 步骤 6 中的图像 1,3 Repair Guide for the LG Net10: 步骤 6 中的图像 2,3 Repair Guide for the LG Net10: 步骤 6 中的图像 3,3
    • Use a wedge, or flat edged tool to separate the phone. Make sure to circle around the entire phone, especially the corners to pull it apart. This can be difficult. This may take several tries, so make sure to be persistent.
  7. Repair Guide for the LG Net10: 步骤 7 中的图像 1,1
    • Separate and remove the two hard covers and the keypad.
  8. Repair Guide for the LG Net10: 步骤 8 中的图像 1,2 Repair Guide for the LG Net10: 步骤 8 中的图像 2,2
    • Then remove the motherboard from the hard back of the phone.
  9. Repair Guide for the LG Net10: 步骤 9 中的图像 1,1
    • Once the phone is completely dissembled, you can replace the screen if it is cracked. You can also replace the keypad if the buttons do not work or if there are other issues with the keypad. Another common desire people have is to unlock the phone. In order to do this, you must replace the SIM card, which is explained in the steps above.
结论
另外一个人完成了本指南。
Gina
于04/15/13注册
146 声望
创作了2篇指南
团队
SUNY Cortland, Team 1-1, Getto Spring 2013 SUNY Cortland, Team 1-1, Getto Spring 2013 的会员
SUNYCORT-GETTO-S13S1G1
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 1,354
