跳转到主内容
Removinging Panasonic DVD-RV31 Player Rear Panel
你所需要的
  1. Removinging Panasonic DVD-RV31 Player Rear Panel, Outer Case: 步骤 1 中的图像 1,2 Removinging Panasonic DVD-RV31 Player Rear Panel, Outer Case: 步骤 1 中的图像 2,2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  2. Removinging Panasonic DVD-RV31 Player Rear Panel: 步骤 2 中的图像 1,1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  3. Removinging Panasonic DVD-RV31 Player Rear Panel, Rear Panel: 步骤 3 中的图像 1,2 Removinging Panasonic DVD-RV31 Player Rear Panel, Rear Panel: 步骤 3 中的图像 2,2
    • Be sure case cover has been removed prior to back panel removal.
    • Remove 5 screws from panel, as shown.
  4. Removinging Panasonic DVD-RV31 Player Rear Panel: 步骤 4 中的图像 1,2 Removinging Panasonic DVD-RV31 Player Rear Panel: 步骤 4 中的图像 2,2
    • Use flat-head screwdriver to push in square tabs, located on each side of the back panel.
    • Use caution, the edges are sharp.
结论
另外一个人完成了本指南。
Kevin
于04/26/11注册
375 声望
创作了8篇指南
团队
Cal Poly, Team 18-20, Garner Spring 2011 Cal Poly, Team 18-20, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G20
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 2,258
