跳转到主内容
Removing the Tower Fan Rotating Blade and Transformer
你所需要的
  1. Removing the Tower Fan Rotating Blade and Transformer, PCB (Printed Circuit Board): 步骤 1 中的图像 1,1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Removing the Tower Fan Rotating Blade and Transformer: 步骤 2 中的图像 1,1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Removing the Tower Fan Rotating Blade and Transformer: 步骤 3 中的图像 1,1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Removing the Tower Fan Rotating Blade and Transformer: 步骤 4 中的图像 1,1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Removing the Tower Fan Rotating Blade and Transformer: 步骤 5 中的图像 1,2 Removing the Tower Fan Rotating Blade and Transformer: 步骤 5 中的图像 2,2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. Removing the Tower Fan Rotating Blade and Transformer, Rotating Blade and Transformer: 步骤 6 中的图像 1,2 Removing the Tower Fan Rotating Blade and Transformer, Rotating Blade and Transformer: 步骤 6 中的图像 2,2
    • In order to remove the fan blade, use pliers to remove the holding nut.
    • After the holding nut is loose, use the pliers to pull up to remove the nut.
  7. Removing the Tower Fan Rotating Blade and Transformer: 步骤 7 中的图像 1,1
    • Remove the two bronze Phillips 29-mm bolts that hold the fan blade to the transformer.
    • Use a pair of pliers to hold the nut at the bottom of the transformer, as you unscrew from left-to-right at the top of the transformer. After, pull up and remove both the screw and nut.
  8. Removing the Tower Fan Rotating Blade and Transformer: 步骤 8 中的图像 1,2 Removing the Tower Fan Rotating Blade and Transformer: 步骤 8 中的图像 2,2
    • Next, remove the two silver Phillips (8-mm head) 40-mm screws from the transformer.
    • Remove screws by pulling them away from the base.
    • The transformer should be free after this step.
结论
Mateo Begue
于09/26/12注册
102 声望
创作了2篇指南
团队
Cal Poly, Team 15-46, Forte Fall 2012 Cal Poly, Team 15-46, Forte Fall 2012 的会员
CPSU-FORTE-F12S15G46
5 名成员
创作了6篇指南
2指南评论
Donde compró el transformador para ventilador servilletas Classics MSC10166
Enrique Vargas - 回复
Deseo comprar el transformador para ventilador serville
Enrique Vargas - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 5,084
