简介
This guide will instruct you on how to remove the fan blade and transformer.
你所需要的
Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
In order to remove the fan blade pliers were used to remove the holding nut.
After the holding nut is loose, use the pliers to pull up to remove the nut.
即将完成!
结论
