配件
无需配件。
  1. Unplug power cable and all AV cables from rear of TV and carefully lay TV face down on a clean flat working surface ensuring that you don't damage the LCD screen.
    • Unplug power cable and all AV cables from rear of TV and carefully lay TV face down on a clean flat working surface ensuring that you don't damage the LCD screen.
    • Using a Philips driver remove the 18 screws from the rear panel.
    • Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
  2. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Remove the 7 connectors from the board
    • Remove the 7 connectors from the board
    • Remove the 7 screws from the board
    • Lift the main board away from the chassis ensuring you don's snag or catch any of the cables.
结论
15等其他人完成本指南。
Richdave
于2010年04月09日注册
28,955 信誉积分
创作了30篇指南
团队
Master Techs Master Techs 的会员
Community
280 名成员
创作了783篇指南
Ma télé LCD Samsung ne veule pas s allume pas de courant que dois je faire s.v.p
Samir Chaaraoui - 回复
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 40
总计 4,882
