跳转到主内容
加入维修社区 - 创建账户
Removing the Phone Keypad
你所需要的
  1. Removing the Phone Keypad, Removing the Back Panel: 步骤 1 中的图像 1,2 Removing the Phone Keypad, Removing the Back Panel: 步骤 1 中的图像 2,2
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Removing the Phone Keypad: 步骤 2 中的图像 1,3 Removing the Phone Keypad: 步骤 2 中的图像 2,3 Removing the Phone Keypad: 步骤 2 中的图像 3,3
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
  3. Removing the Phone Keypad, Keypad: 步骤 3 中的图像 1,2 Removing the Phone Keypad, Keypad: 步骤 3 中的图像 2,2
    • Locate and unscrew the circled screw using a Philips head #2 screw driver or screw driver head.
  4. Removing the Phone Keypad: 步骤 4 中的图像 1,1
    • Lift the motherboard away from the phone housing.
    • Be careful when lifting the motherboard. To prevent damage to the motherboard, gradually lift it from its place in the assembly.
  5. Removing the Phone Keypad: 步骤 5 中的图像 1,2 Removing the Phone Keypad: 步骤 5 中的图像 2,2
    • Now that the motherboard has been lifted out of place, the keypad can be accessed.
    • Using your fingers push the buttons from the the phone toward the lifted motherboard.
    • Remove the keypad from the assembly.
结论
Elizabeth Kelly
于10/22/12注册
501 声望
创作了5篇指南
团队
Clemson, Team 15-1, Benson Fall 2012 Clemson, Team 15-1, Benson Fall 2012 的会员
CLEM-BENSON-F12S15G1
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 67
总计 1,326
