当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Gently pull on the bottom of the slider until it comes off the lower track.
There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
Be careful not to completely pull the front case off because it will still be connected with wires.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
