跳转到主内容
Removing the Olympus Stylus 410 Outer Case
你所需要的
  1. Removing the Olympus Stylus 410 Outer Case, Slider: 步骤 1 中的图像 1,1
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Removing the Olympus Stylus 410 Outer Case: 步骤 2 中的图像 1,1
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Removing the Olympus Stylus 410 Outer Case: 步骤 3 中的图像 1,1
    • Lift the slider up until it comes off the upper track.
  4. Removing the Olympus Stylus 410 Outer Case: 步骤 4 中的图像 1,1
    • The slider should now be free from the body of the camera.
  5. Removing the Olympus Stylus 410 Outer Case, Outer Case: 步骤 5 中的图像 1,3 Removing the Olympus Stylus 410 Outer Case, Outer Case: 步骤 5 中的图像 2,3 Removing the Olympus Stylus 410 Outer Case, Outer Case: 步骤 5 中的图像 3,3
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  6. Removing the Olympus Stylus 410 Outer Case: 步骤 6 中的图像 1,2 Removing the Olympus Stylus 410 Outer Case: 步骤 6 中的图像 2,2
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  7. Removing the Olympus Stylus 410 Outer Case: 步骤 7 中的图像 1,2 Removing the Olympus Stylus 410 Outer Case: 步骤 7 中的图像 2,2
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  8. Removing the Olympus Stylus 410 Outer Case: 步骤 8 中的图像 1,2 Removing the Olympus Stylus 410 Outer Case: 步骤 8 中的图像 2,2
    • Remove the memory card.
    • Locate and remove the 2 screws using a #00 Phillips screwdriver.
  9. Removing the Olympus Stylus 410 Outer Case: 步骤 9 中的图像 1,3 Removing the Olympus Stylus 410 Outer Case: 步骤 9 中的图像 2,3 Removing the Olympus Stylus 410 Outer Case: 步骤 9 中的图像 3,3
    • Use a spudger around the edge of the case to loosen it.
    • Carefully wiggle the back case off. This may require a fair amount of force.
  10. Removing the Olympus Stylus 410 Outer Case: 步骤 10 中的图像 1,1
    • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  11. Removing the Olympus Stylus 410 Outer Case: 步骤 11 中的图像 1,2 Removing the Olympus Stylus 410 Outer Case: 步骤 11 中的图像 2,2
    • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
    • Be careful not to completely pull the front case off because it will still be connected with wires.
结论
另外一个人完成了本指南。
Jared Ruekberg
于04/15/10注册
33 声望
创作了2篇指南
团队
Cal Poly, Team 6-13, Maness Spring 2010 Cal Poly, Team 6-13, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G13
5 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 2,532
