跳转到主内容
Removing the Logitech MBJ58 Scroll Wheel from its Mount
你所需要的
  1. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Top cover: 步骤 1 中的图像 1,1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Removing the Logitech MBJ58 Scroll Wheel from its Mount: 步骤 2 中的图像 1,2 Removing the Logitech MBJ58 Scroll Wheel from its Mount: 步骤 2 中的图像 2,2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: 步骤 3 中的图像 1,3 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: 步骤 3 中的图像 2,3 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: 步骤 3 中的图像 3,3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
  4. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Support Spring: 步骤 4 中的图像 1,2 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Support Spring: 步骤 4 中的图像 2,2
    • Locate the spring on the scroll wheel, and carefully remove the spring.
  5. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Attaching the New Spring: 步骤 5 中的图像 1,2 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Attaching the New Spring: 步骤 5 中的图像 2,2
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
  6. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: 步骤 6 中的图像 1,3 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: 步骤 6 中的图像 2,3 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: 步骤 6 中的图像 3,3
    • Locate the black wheel mount.
    • Note: Make sure that the spring hidden in the mount does not fall out.
    • Separate the wheel from its mount.
结论
2等其他人完成本指南。
Conor Whatley
于01/11/13注册
510 声望
创作了3篇指南
团队
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013 的会员
CPSU-FORTE-W13S5G14
5 名成员
创作了23篇指南
2指南评论
Thank you! The photographs with good resolution and correct lighting made everything clear and comprehencible.
Антон Вакаренко - 回复
Very helpful, thank you!
K.S. - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 35
总计 2,003
