简介
This guide will show you how to remove the switch cover assembly from the laptop.
  1. Flip laptop over and locate the battery release button Push release button to the left to release battery and gently pull battery from the laptop Push release button to the left to release battery and gently pull battery from the laptop
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard Slide the retention clips toward the keyboard to release the keyboard
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Use a plastic pry tool to lift the rear edge of the keyboard. Pull  the keyboard slightly towards the display to disengage  the tabs along the front of the keyboard from the laptop palm rest. Lift the keyboard up to reveal the ribbon connectors
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  5. Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable Release the smaller ribbon cable by lifting up the white retainer I found it easier to reinstall both cables with the new keyboard resting on the back edge
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  6. Remove the two M2.0×4.0 broad-head screws. Remove the three Torx T8 M2.5×7.0 screws. Remove the three Torx T8 M2.5×7.0 screws.
    • Remove the two M2.0×4.0 broad-head screws.
    • Remove the three Torx T8 M2.5×7.0 screws.
  7. Turn the computer over with the front toward you and the open the computer as far as possible. Release the ZIF connector for the power button board cable. Remove the switch cover by lifting it straight up and flip it forward.
    • Turn the computer over with the front toward you and the open the computer as far as possible.
    • Release the ZIF connector for the power button board cable.
    • Remove the switch cover by lifting it straight up and flip it forward.
    • Release the ZIF connector for the LED board cable.
结论
2等其他人完成本指南。
Richdave
于2010年04月09日注册
29,106 信誉积分
创作了30篇指南
团队
Master Techs Master Techs 的会员
Community
286 名成员
创作了801篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 6
总计 1,453
