跳转到主内容
Removing the HP Elitebook 6930p RTC (CMOS) Battery
你所需要的
  1. Removing the HP Elitebook 6930p RTC (CMOS) Battery, Battery Removal: 步骤 1 中的图像 1,3 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Battery Removal: 步骤 1 中的图像 2,3 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Battery Removal: 步骤 1 中的图像 3,3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p RTC (CMOS) Battery, Keyboard: 步骤 2 中的图像 1,3 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Keyboard: 步骤 2 中的图像 2,3 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Keyboard: 步骤 2 中的图像 3,3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p RTC (CMOS) Battery: 步骤 3 中的图像 1,3 Removing the HP Elitebook 6930p RTC (CMOS) Battery: 步骤 3 中的图像 2,3 Removing the HP Elitebook 6930p RTC (CMOS) Battery: 步骤 3 中的图像 3,3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p RTC (CMOS) Battery: 步骤 4 中的图像 1,3 Removing the HP Elitebook 6930p RTC (CMOS) Battery: 步骤 4 中的图像 2,3 Removing the HP Elitebook 6930p RTC (CMOS) Battery: 步骤 4 中的图像 3,3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p RTC (CMOS) Battery, RTC (CMOS) Battery: 步骤 5 中的图像 1,2 Removing the HP Elitebook 6930p RTC (CMOS) Battery, RTC (CMOS) Battery: 步骤 5 中的图像 2,2
    • Locate the the battery
    • If the battery wires are running underneath the WLAN module you will have to remove it first. In my case it was necessary to remove the WLAN module.
    • Disconnect the battery from the connector
    • Removal of this battery will not clear a BIOS password on the HP Elitebook 6930P and some other Business Class notebooks.
    • Gently un-clip the battery from the plastic housing to completely remove it from the laptop
结论
10等其他人完成本指南。
Richdave
于04/09/10注册
32,063 声望
创作了30篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
8条评论
This did not work for me. I left the CMOS battery disconnected for a day.
You need to contact HP to get this resolved.
http://h30434.www3.hp.com/t5/Notebook-Op...
Wm Brian Savacool - 回复
This didn't work for me
Depinder Bharti - 回复
I can't even boot
Hugo Escobar - 回复
cool i like the explanation
Nartey Levis - 回复
Τελικά μπορούμε με κάποιο τρόπο να αφαιρέσουμε κωδικό πρόσβασης BIOS για την HP EliteBook 6930p????
Αν όχι μήπως θα λειτουργούσε ένας δίσκος λειτουργικού γραμμένος από ένα άλλο HP EliteBook 6930p ώστε να μην χρειαστούμε πρόσβασης BIOS?????
ΠΑΝΑΓΙΩΤΗΣ ΓΙΑΝΝΑΚΑΚΗΣ - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 95
总计 40,870
