跳转到主内容
Removing the HP Elitebook 6930p Hard Drive
你所需要的
  1. Removing the HP Elitebook 6930p Hard Drive, Battery Removal: 步骤 1 中的图像 1,3 Removing the HP Elitebook 6930p Hard Drive, Battery Removal: 步骤 1 中的图像 2,3 Removing the HP Elitebook 6930p Hard Drive, Battery Removal: 步骤 1 中的图像 3,3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Hard Drive, Hard Drive: 步骤 2 中的图像 1,3 Removing the HP Elitebook 6930p Hard Drive, Hard Drive: 步骤 2 中的图像 2,3 Removing the HP Elitebook 6930p Hard Drive, Hard Drive: 步骤 2 中的图像 3,3
    • With the bottom of the laptop facing up and the front toward you locate and loosen the two M2.0×5.0 captive screws holding the hard drive bay cover closed.
    • Lift the left side of the bay cover and swing it up and to the right to remove it.
    • Loosen the M2.5×10.0 captive screw that holds the hard drive in.
    • Grasp the plastic tab and slide the hard drive to the right to disconnect it from the motherboard.
    • Lift the hard drive straight up and out of the laptop.
  3. Removing the HP Elitebook 6930p Hard Drive: 步骤 3 中的图像 1,2 Removing the HP Elitebook 6930p Hard Drive: 步骤 3 中的图像 2,2
    • To remove the hard drive from the bracket remove the two M3.0×4.0 screws from each side of the hard drive.
结论
17等其他人完成本指南。
Richdave
于04/09/10注册
32,063 声望
创作了30篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,535篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 27
总计 9,674
