跳转到主内容
Removing the HP Elitebook 6930p Bluetooth module
你所需要的
  1. Removing the HP Elitebook 6930p Bluetooth module, Battery Removal: 步骤 1 中的图像 1,3 Removing the HP Elitebook 6930p Bluetooth module, Battery Removal: 步骤 1 中的图像 2,3 Removing the HP Elitebook 6930p Bluetooth module, Battery Removal: 步骤 1 中的图像 3,3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Bluetooth module, Bluetooth module: 步骤 2 中的图像 1,3 Removing the HP Elitebook 6930p Bluetooth module, Bluetooth module: 步骤 2 中的图像 2,3 Removing the HP Elitebook 6930p Bluetooth module, Bluetooth module: 步骤 2 中的图像 3,3
    • Locate the Bluetooth module cover on the bottom of the laptop
    • Loosen the M2.0×5.0 captive screw and remove the cover by by lifting it straight up
    • The Bluetooth module is connected to the laptop via a small cable with very fine wires - take care not to damage the cable when you pull the module out of the case.
    • Gently lift the Bluetooth module up and over the retaining clip. A plastic spudger may be useful.
    • Disconnect the connector being careful not to damage the fine wires on the cable.
结论
4等其他人完成本指南。
Richdave
于04/09/10注册
32,063 声望
创作了30篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 5,011
