简介
This guide will show you how to remove the optical (cd) drive from your HP Compaq dx2000MT.
配件
无需配件。
  1. Turn off your computer and remove the power cable by pulling it straight out of its socket.
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Remove the 2 Phillips #2 screws that secure the case door to the device. Remove the 2 Phillips #2 screws that secure the case door to the device.
    • Remove the 2 Phillips #2 screws that secure the case door to the device.
  3. Remove the side case door by pushing towards the rear of the device with your hand. This may take considerable force so keep pushing! Once you slide the door back, remove it by pulling it outwards from the device.
    • Remove the side case door by pushing towards the rear of the device with your hand.
      • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  5. Remove the side case door by pushing towards the rear of the device with your hand. Once again, this may take considerable force. Once you slide the door back, remove it by pulling it outwards from the device.
      • Once again, this may take considerable force.
  6. Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive. Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive. Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
    • Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
  7. Remove the 2 Torx T15 screws holding the optical drive in place. Remove the 2 Torx T15 screws holding the optical drive in place.
    • Remove the 2 Torx T15 screws holding the optical drive in place.
  8. Remove the other 2 Torx T15 screws holding the other side of the drive in place. Remove the other 2 Torx T15 screws holding the other side of the drive in place.
    • Remove the other 2 Torx T15 screws holding the other side of the drive in place.
  9. Remove the optical drive by sliding it out the front of the device. Remove the optical drive by sliding it out the front of the device. Remove the optical drive by sliding it out the front of the device.
    • Remove the optical drive by sliding it out the front of the device.
结论
Logan Pace
于2011年10月12日注册
2,020 信誉积分
创作了9篇指南
团队
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G16
4 名成员
创作了17篇指南
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 1
总计 1,216
