跳转到主内容
Removing the Dell Inspiron 1150 Modem Card
你所需要的
  1. Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: 步骤 1 中的图像 1,3 Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: 步骤 1 中的图像 2,3 Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: 步骤 1 中的图像 3,3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Modem Card, Modem Card: 步骤 2 中的图像 1,3 Removing the Dell Inspiron 1150 Modem Card, Modem Card: 步骤 2 中的图像 2,3 Removing the Dell Inspiron 1150 Modem Card, Modem Card: 步骤 2 中的图像 3,3
    • Turn the laptop upside down and locate the panel labeled C
    • Unscrew the single screw holding the cover in place.
    • Lift up the cover and remove it to expose the Modem Card.
  3. Removing the Dell Inspiron 1150 Modem Card: 步骤 3 中的图像 1,2 Removing the Dell Inspiron 1150 Modem Card: 步骤 3 中的图像 2,2
    • Locate the Modem card.
    • Remove the screws.
  4. Removing the Dell Inspiron 1150 Modem Card: 步骤 4 中的图像 1,2 Removing the Dell Inspiron 1150 Modem Card: 步骤 4 中的图像 2,2
    • Pull tab to lift the card out of the connector on the main board.
    • Disconnect the cable attached to the left edge of the Modem card
终点
Lauren
于04/25/10注册
4 声望
创作了2篇指南
团队
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G2
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 4,517
