本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will show you how to remove the keyboard on your Dell 1150 laptop
你所需要的
Place the laptop upside down on a clean, flat surface.
Locate the battery release button with the padlock symbol above it.
Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
Gently remove the battery from the side of the laptop.
Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
Lift the hinge cover off and set aside
另外一个人完成了本指南。
