跳转到主内容
Removing the Dell Inspiron 1150 Keyboard
你所需要的
  1. Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: 步骤 1 中的图像 1,3 Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: 步骤 1 中的图像 2,3 Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: 步骤 1 中的图像 3,3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Keyboard, Keyboard: 步骤 2 中的图像 1,3 Removing the Dell Inspiron 1150 Keyboard, Keyboard: 步骤 2 中的图像 2,3 Removing the Dell Inspiron 1150 Keyboard, Keyboard: 步骤 2 中的图像 3,3
    • Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
    • You need to lay the LCD screen down flat to allow the hinge cover to be lifted off
    • Lift the hinge cover off and set aside
  3. Removing the Dell Inspiron 1150 Keyboard: 步骤 3 中的图像 1,3 Removing the Dell Inspiron 1150 Keyboard: 步骤 3 中的图像 2,3 Removing the Dell Inspiron 1150 Keyboard: 步骤 3 中的图像 3,3
    • Remove 4ea M2 x 3mm keyboard screws
    • Lift up keyboard from the rear to expose the connector below
    • Disconnect the keyboard ribbon cable from the mother board
结论
另外一个人完成了本指南。
Richdave
于04/09/10注册
32,287 声望
创作了30篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,525篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 889
