跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide is inspired by the Dell 1150 Service Manual and all steps are in accordance with it.
配件
没有特定配件。
  1. Place the laptop upside down on a clean, flat surface. Locate the battery release button with the padlock symbol above it. Slide the battery release button towards the padlock symbol and hold it there.  Note that the button is spring loaded and will return if released.
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Place laptop upside down on a clean flat surface. Remove 2ea M2.5 x 5 mm screws.
    • Place laptop upside down on a clean flat surface.
    • Remove 2ea M2.5 x 5 mm screws.
    • Pull the HDD from main body of the laptop.
  3. Place laptop upsid down on a clean flat work surface. Remove the Philips M2.5 x 8 mm screw Loosen the screw that holds the memory compartment closed
    • Place laptop upsid down on a clean flat work surface.
    • Remove the Philips M2.5 x 8 mm screw
    • Loosen the screw that holds the memory compartment closed
    • remove the memory module compartment cover
    • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
  4. Manta 螺丝刀工具包
    日常维修的112个替换头
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  5. Use a spudger to lift the notched right edge of the hinge cover, and pry it loose You need to lay the LCD screen down flat to allow the hinge cover to be lifted off Lift the hinge cover off and set aside
    • Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
    • You need to lay the LCD screen down flat to allow the hinge cover to be lifted off
    • Lift the hinge cover off and set aside
  6. Remove 4ea  M2 x 3mm keyboard screws Lift up keyboard from the rear to expose the connector below Disconnect the keyboard ribbon cable from the mother board
    • Remove 4ea M2 x 3mm keyboard screws
    • Lift up keyboard from the rear to expose the connector below
    • Disconnect the keyboard ribbon cable from the mother board
  7. Remove 1ea M2.5 x 8mm screw holding the EMI shield in place Remove the EMI shield to expose the LCD ribbon cable Gently pull up on the tab to disconnect the ribbon cable from the main board
    • Remove 1ea M2.5 x 8mm screw holding the EMI shield in place
    • Remove the EMI shield to expose the LCD ribbon cable
    • Gently pull up on the tab to disconnect the ribbon cable from the main board
    • Close the lid carefully and remove the two M2.5 x 5-mm screws from the rear of the case
  8. Open the lid and support the Display Assembly while performing the next step to avoid it falling down when the hinge screws are removed Remove 2e M2.5 x 5mm screws from each hinge bracket The Display Assembly can now be lifted free of the laptop body
    • Open the lid and support the Display Assembly while performing the next step to avoid it falling down when the hinge screws are removed
    • Remove 2e M2.5 x 5mm screws from each hinge bracket
    • The Display Assembly can now be lifted free of the laptop body
结论
2等其他人完成本指南。
Daniel
于2010年04月25日注册
87 信誉积分
创作了2篇指南
团队
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G2
4 名成员
创作了9篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 6,705
