跳转到主内容
Removing the Back Panel
你所需要的
  1. Removing the Back Panel, Removing the Back Panel: 步骤 1 中的图像 1,3 Removing the Back Panel, Removing the Back Panel: 步骤 1 中的图像 2,3 Removing the Back Panel, Removing the Back Panel: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Removing the Back Panel: 步骤 2 中的图像 1,3 Removing the Back Panel: 步骤 2 中的图像 2,3 Removing the Back Panel: 步骤 2 中的图像 3,3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
结论
4等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 11
过去 30 天: 37
总计 2,794
