跳转到主内容
Removing the Anti-Glare Coating from a MacBook Pro Screen
你所需要的
  1. Removing the Anti-Glare Coating from a MacBook Pro Screen, Removing the Anti-Glare Coating from a MacBook Pro Screen: 步骤 1 中的图像 1,2 Removing the Anti-Glare Coating from a MacBook Pro Screen, Removing the Anti-Glare Coating from a MacBook Pro Screen: 步骤 1 中的图像 2,2
    • Power off the MacBook by clicking on the Apple logo in the top left corner of the screen. Then, scroll down the list and click "Shut Down."
    • Disconnect any attached cables such as chargers or wired headphones.
    • Disconnecting cables before beginning this repair is crucial to avoid moisture damage and electrical shocks. Cables should not be present in order to fully clean the ports and connectors.
  2. Removing the Anti-Glare Coating from a MacBook Pro Screen: 步骤 2 中的图像 1,2 Removing the Anti-Glare Coating from a MacBook Pro Screen: 步骤 2 中的图像 2,2
    • Gently wipe the screen's surface with either a microfiber cloth or cotton pad to remove any residual dust or oil.
  3. Removing the Anti-Glare Coating from a MacBook Pro Screen: 步骤 3 中的图像 1,1
    • Apply a mild plastic polish or cleaning solution like Bar Keeper’s Friend (liquid) to a cotton pad.
  4. Removing the Anti-Glare Coating from a MacBook Pro Screen: 步骤 4 中的图像 1,2 Removing the Anti-Glare Coating from a MacBook Pro Screen: 步骤 4 中的图像 2,2
    • Softly rub the coating from the cotton pad onto the MacBook's screen in small circular motions.
    • Be careful not to damage the screen underneath.
  5. Removing the Anti-Glare Coating from a MacBook Pro Screen: 步骤 5 中的图像 1,1
    • Wipe the screen clean with a new microfiber cloth or cotton pad. Inspect for remaining coating.
    • If the damaged anti-glare coating still remains, repeat this process as many times as needed.
终点
Nicole Vo
于05/12/25注册
121 声望
撰写一个指南
团队
UC Davis, Team 1-4, Whithaus Spring 2025 UC Davis, Team 1-4, Whithaus Spring 2025 的会员
UCD-WHITHAUS-S25S1G4
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 116
总计 468
