跳转到主内容
加入维修社区 - 创建账户
Removing Texas Instruments TI-92 Back Cover
  1. Removing Texas Instruments TI-92 Back Cover, Back Cover: 步骤 1 中的图像 1,3 Removing Texas Instruments TI-92 Back Cover, Back Cover: 步骤 1 中的图像 2,3 Removing Texas Instruments TI-92 Back Cover, Back Cover: 步骤 1 中的图像 3,3
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
  2. Removing Texas Instruments TI-92 Back Cover: 步骤 2 中的图像 1,2 Removing Texas Instruments TI-92 Back Cover: 步骤 2 中的图像 2,2
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
  3. Removing Texas Instruments TI-92 Back Cover: 步骤 3 中的图像 1,2 Removing Texas Instruments TI-92 Back Cover: 步骤 3 中的图像 2,2
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
结论
团队
Cal Poly, Team 15-51, Garner Spring 2010 Cal Poly, Team 15-51, Garner Spring 2010 的会员
CPSU-GARNER-S10S15G51
5 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 25
总计 3,628
