跳转到主内容
Removing Samsung ML2510 Back Panel
你所需要的
  1. Removing Samsung ML2510 Back Panel, Removing Samsung ML2510 Back Panel: 步骤 1 中的图像 1,3 Removing Samsung ML2510 Back Panel, Removing Samsung ML2510 Back Panel: 步骤 1 中的图像 2,3 Removing Samsung ML2510 Back Panel, Removing Samsung ML2510 Back Panel: 步骤 1 中的图像 3,3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Removing Samsung ML2510 Back Panel: 步骤 2 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Removing Samsung ML2510 Back Panel: 步骤 3 中的图像 1,3 Removing Samsung ML2510 Back Panel: 步骤 3 中的图像 2,3 Removing Samsung ML2510 Back Panel: 步骤 3 中的图像 3,3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
结论
4等其他人完成本指南。
bbaustin
于10/12/11注册
268 声望
创作了6篇指南
团队
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G18
4 名成员
创作了12篇指南
3条评论
Very easy to follow. I think I would have broken something if I had not followed these simple steps.
rob - 回复
Thank you on how to do this. A little force is required to lift the top cover edges one by one to get the back cover off, but it does come off, without taking the top cover off. I think my solenoid is bad, as the printer takes two sheets of paper initially and then more right afterwards. The rubber pick up wheel seems to be fine after cleaning, as it picks up the paper without issue, just multiple sheets is all.
kirkdcharles - 回复
Thanks. I would have broken the top cover or back panel if I did not read your post. It take a little force to pull the back cover off while applying upward pressure to the top cover ends, one at a time. I think I have to replace the solenoid as the rubber pick up wheel pulls the paper up fine, but multiple sheets after the first rotation of the wheel.
kirkdcharles - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 6,103
