当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Open the tray by pressing the eject button
Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
Press the eject button to insert the tray
After the tray is closed unplug DVD player
Unscrew the 3 screws in the back.
Pull the outer case upward and then towards you.
There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
Locate the white clip that attaches the cord to the motherboard
Grasp clip and squeeze to release
Lift up and remove power cord
Slide cord mount from outer case
Remove the three screws holding in the DVD tray
Remove the power cord and first two ribbons by pulling them directly out of their sockets.
Gently lift the DVD tray off of the motherboard.
Unscrew the 2 screws on the motherboard
Unscrew the 2 screws on the back
Disconnect the wires and ribbon by pulling them out of their respective connections
Lift board up and out of the lower case
取消:我没有完成这个指南。
另外一个人完成了本指南。
与7其他贡献者
于01/21/11注册
903 声望
创作了5篇指南
徽章: 12
+ 9更多徽章
CPSU-REGAN-W11S3G30
4 名成员
创作了8篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 3,209
