跳转到主内容
修复你的物品
维修的权力
商店
配件
没有特定配件。
  1. Open the tray by pressing the eject button Remove the DVD tray faceplate by pushing the faceplate up off of the tray. Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Press the eject button to insert the tray
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Unscrew the 3 screws in the back.
    • Unscrew the 3 screws in the back.
  4. Pull the outer case upward and then towards you. Pull the outer case upward and then towards you.
    • Pull the outer case upward and then towards you.
  5. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate.
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. 打开所有标签
    Mac的RAM升级套装
    购买套装
    所有选项卡都有足够的 RAM
    购买套装
  7. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  8. Locate the white clip that attaches the cord to the motherboard Grasp clip and squeeze to release Lift up and remove power cord
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  9. Remove the three screws holding in the DVD tray Remove the three screws holding in the DVD tray Remove the three screws holding in the DVD tray
    • Remove the three screws holding in the DVD tray
  10. Remove the power cord and first two ribbons by pulling them directly out of their sockets. Remove the power cord and first two ribbons by pulling them directly out of their sockets.
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  11. Gently lift the DVD tray off of the motherboard. Gently lift the DVD tray off of the motherboard.
    • Gently lift the DVD tray off of the motherboard.
  12. Unscrew the 2 screws on the motherboard Unscrew the 2 screws on the back
    • Unscrew the 2 screws on the motherboard
    • Unscrew the 2 screws on the back
  13. Disconnect the wires and ribbon by pulling them out of their respective connections Disconnect the wires and ribbon by pulling them out of their respective connections Disconnect the wires and ribbon by pulling them out of their respective connections
    • Disconnect the wires and ribbon by pulling them out of their respective connections
  14. Lift board up and out of the lower case Lift board up and out of the lower case
    • Lift board up and out of the lower case
结论
另外一个人完成了本指南。
Mitchell Hart
于2011年01月21日注册
894 信誉积分
创作了5篇指南
团队
Cal Poly, Team 3-30, Regan Winter 2011 Cal Poly, Team 3-30, Regan Winter 2011 的会员
CPSU-REGAN-W11S3G30
4 名成员
创作了8篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 7
总计 3,023
