跳转到主内容
Removing RAM from HP Elitebook 6930p
你所需要的
  1. Removing RAM from HP Elitebook 6930p, Battery Removal: 步骤 1 中的图像 1,3 Removing RAM from HP Elitebook 6930p, Battery Removal: 步骤 1 中的图像 2,3 Removing RAM from HP Elitebook 6930p, Battery Removal: 步骤 1 中的图像 3,3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing RAM from HP Elitebook 6930p, Keyboard: 步骤 2 中的图像 1,3 Removing RAM from HP Elitebook 6930p, Keyboard: 步骤 2 中的图像 2,3 Removing RAM from HP Elitebook 6930p, Keyboard: 步骤 2 中的图像 3,3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing RAM from HP Elitebook 6930p: 步骤 3 中的图像 1,3 Removing RAM from HP Elitebook 6930p: 步骤 3 中的图像 2,3 Removing RAM from HP Elitebook 6930p: 步骤 3 中的图像 3,3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing RAM from HP Elitebook 6930p: 步骤 4 中的图像 1,3 Removing RAM from HP Elitebook 6930p: 步骤 4 中的图像 2,3 Removing RAM from HP Elitebook 6930p: 步骤 4 中的图像 3,3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing RAM from HP Elitebook 6930p, RAM: 步骤 5 中的图像 1,2 Removing RAM from HP Elitebook 6930p, RAM: 步骤 5 中的图像 2,2
    • Locate RAM module
    • Push metal tabs outwards away from the RAM module to release it.
    • The RAM module will spring up and can be removed from the RAM slot.
结论
21等其他人完成本指南。
Richdave
于04/09/10注册
32,150 声望
创作了30篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,464篇指南
7条评论
HP Elitebook 6930p. Huh !!!!
Desingn constructor is the largest manufacturer idiot. Put one memory slot inside, located under the keyboard denotes an unparalleled stupidity.
astorp2000 - 回复
I agree with above comment, weird thing to do.
S Cleaver - 回复
Thanks for your splendid guide. I don't have a plastic pry tool. A bass guitar plectrum works just as well though. The whole job took under 10 mins to complete. I now have X2, 2GB memory cards installed. This is plenty to run Manjaro JWM 16,04.1. It boots up only using 180 MB of RAM - perfect.
Andy Mitchell - 回复
Great guide. Trying to part out computer and couldn't figure out where other memory slot located. Agree dumb place for it.
Been Allison - 回复
the ram is acessible through the door in the middle, need to unscrew 2 screws LOL
Lukasz Nowakowski - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 68
总计 30,657
