跳转到主内容
简介
Removing and replacing the DVD-ROM drive.
配件
没有特定配件。
  1. Pull on outer latch. Lower door until it is level with your work surface.
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Removing the faceplate. On the inside of the case, find the two plastic tabs.
    • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
  3. Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
    • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
  4. Pull the drive out to allow access to the power and ribbon cables. Do not fully remove. Remove both the power and ribbon cable. Remove both the power and ribbon cable.
    • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
    • Remove both the power and ribbon cable.
终点
25等其他人完成本指南。
Justin Petrilli
于2010年01月21日注册
3,030 信誉积分
创作了11篇指南
团队
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G24
4 名成员
创作了25篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 23
总计 9,690
