跳转到主内容
Removing PowerMac G4 M5183 DVD-ROM Drive Tray
你所需要的
  1. Removing PowerMac G4 M5183 DVD-ROM Drive Tray, Opening PowerMac G4 M5183 Case: 步骤 1 中的图像 1,2 Removing PowerMac G4 M5183 DVD-ROM Drive Tray, Opening PowerMac G4 M5183 Case: 步骤 1 中的图像 2,2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Removing PowerMac G4 M5183 DVD-ROM Drive Tray, DVD-ROM Drive: 步骤 2 中的图像 1,2 Removing PowerMac G4 M5183 DVD-ROM Drive Tray, DVD-ROM Drive: 步骤 2 中的图像 2,2
    • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
  3. Removing PowerMac G4 M5183 DVD-ROM Drive Tray: 步骤 3 中的图像 1,1
    • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
  4. Removing PowerMac G4 M5183 DVD-ROM Drive Tray: 步骤 4 中的图像 1,3 Removing PowerMac G4 M5183 DVD-ROM Drive Tray: 步骤 4 中的图像 2,3 Removing PowerMac G4 M5183 DVD-ROM Drive Tray: 步骤 4 中的图像 3,3
    • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
    • Remove both the power and ribbon cable.
终点
26等其他人完成本指南。
Justin Petrilli
于01/21/10注册
3,114 声望
创作了11篇指南
团队
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G24
4 名成员
创作了25篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 43
总计 10,533
